Ana içeriğe geç
HP Pavilion Wave 600-a014 System Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion Wave 600-a014 System Fan Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Disconnect the PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 System Fan Replacement: adım 2, 2 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement: adım 2, 2 resimden 2.
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 System Fan Replacement: adım 3, 2 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement: adım 3, 2 resimden 2.
    • Remove the two cables circled in red for the front IO panel.
  4. HP Pavilion Wave 600-a014 System Fan Replacement: adım 4, 2 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement: adım 4, 2 resimden 2.
    • From back IO panel pry open the casing as indicated.
  5. HP Pavilion Wave 600-a014 System Fan Replacement: adım 5, 3 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement: adım 5, 3 resimden 2. HP Pavilion Wave 600-a014 System Fan Replacement: adım 5, 3 resimden 3.
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  6. HP Pavilion Wave 600-a014 System Fan Replacement: adım 6, 1 resimden 1.
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
  7. HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: adım 7, 2 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: adım 7, 2 resimden 2.
    • After removing your hard drive, remove the two 1.2mm Phillips #1 screws from the bottom of your case .
  8. HP Pavilion Wave 600-a014 System Fan Replacement: adım 8, 2 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement: adım 8, 2 resimden 2.
    • Remove the 8 mm Phillips #0 screw that is connected the top bezel and the top cover using the driver kit.
  9. HP Pavilion Wave 600-a014 System Fan Replacement: adım 9, 2 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement: adım 9, 2 resimden 2.
    • Using a flathead screwdriver, remove the 8 mm Phillips #1 screw that connects the body casing and the top bezel(the one at the bottom of memory card slot).
  10. HP Pavilion Wave 600-a014 System Fan Replacement: adım 10, 1 resimden 1.
    • Remove the top bezel.
    • You will have to take off a pair of wire connecting the bezel with the body to be able to completely detach it.
  11. HP Pavilion Wave 600-a014 System Fan Replacement: adım 11, 3 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement: adım 11, 3 resimden 2. HP Pavilion Wave 600-a014 System Fan Replacement: adım 11, 3 resimden 3.
    • Turn the device to the top side where you can see the top cover and the speaker.
    • Using a flathead or Phillips #1 screwdriver, unscrew all the eight 8.0 mm screws that connect the top cover to the other components of the casing.
    • Gently remove the top cover.
  12. HP Pavilion Wave 600-a014 System Fan Replacement: adım 12, 3 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement: adım 12, 3 resimden 2. HP Pavilion Wave 600-a014 System Fan Replacement: adım 12, 3 resimden 3.
    • After removing the top cover, locate the system fan on the left side of memory compartment.
    • Remove three 1.2 cm Phillips #1 screws that connect the fan with the main body.
  13. HP Pavilion Wave 600-a014 System Fan Replacement: adım 13, 2 resimden 1. HP Pavilion Wave 600-a014 System Fan Replacement: adım 13, 2 resimden 2.
    • Simply slide up the fan after removing the screws.
Sonuç
Kyaw Soe
321 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G4, Banghart Fall 2017 Cal Poly, Team S8-G4, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,169
