Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Begin by turning the laptop over so that you can see the bottom of the computer.
Slide the battery release switch to the right while simultaneously lifting up the battery.
Loosen the eight Phillips screws around the plate to remove it.
Remove the nine Phillips screws from the plate covering the fans.
Disconnect the lower fan connector from the motherboard.
Remove the metal plate and lower fan.
Disconnect the upper fan connector from the motherboard.
Remove the four spring loaded screws holding the heat sink assembly to the motherboard.
Slide the heat sink assembly including the upper fan out by pulling it down and left simultaneously.
Remove the screws holding the keyboard to the chassis.
Unplug the wire just below the right screw shown and the small white connector to the left of that screw.
The far end of the keyboard bezel may still be held by two screws that can only be accessed by removing the optical drive (as mentioned in Step 9).
Disconnect the three ribbon cables attached to the motherboard.
See images 2 and 3 for a closer look.
Remove the screws from the motherboard.
There are many different sizes and types of screws here. Make sure you are keeping track of where they all belong.
Slide out the optical drive if it wasn't removed in Step 9.
Pry the frame off the laptop outwards while simultaneously lifting the motherboard out of it.
To remove the second speaker simply lift it up and out.
