Ana içeriğe geç
HP Pavilion ZD7000 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 2 resimden 1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 2 resimden 2.
    • Unscrew the 2 screws from the plate that cover the Wi-Fi card.
    • Remove the cover.
  4. HP Pavilion ZD7000 Wi-Fi Card Replacement: adım 4, 2 resimden 1. HP Pavilion ZD7000 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Disconnect these 2 antenna wires (which eventually connect to the monitor) from the Wi-Fi card.
    • For reassembly, note where the black and white cables connect to the card.
    • Release the Wi-Fi card from the laptop by pressing the metal hinges on either end of it.
    • Gently remove the card from laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Shantel
545 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 30-37, Garner Spring 2010 Cal Poly, Team 30-37, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G37
4 Üyeler
2 Yorum
Can you upgrade the wifi card?
danoco - Yanıt
is there a replacement I can buy
Braeden Culp - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 5,436
