Ana içeriğe geç
HP Pavilion dm4-1265dx Clock Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion dm4-1265dx Clock Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Clock Battery Replacement: adım 2, 3 resimden 1. HP Pavilion dm4-1265dx Clock Battery Replacement: adım 2, 3 resimden 2. HP Pavilion dm4-1265dx Clock Battery Replacement: adım 2, 3 resimden 3.
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: adım 3, 2 resimden 1. HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: adım 3, 2 resimden 2.
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Clock Battery Replacement: adım 4, 3 resimden 1. HP Pavilion dm4-1265dx Clock Battery Replacement: adım 4, 3 resimden 2. HP Pavilion dm4-1265dx Clock Battery Replacement: adım 4, 3 resimden 3.
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: adım 5, 3 resimden 1. HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: adım 5, 3 resimden 2. HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • The clock battery is a metallic disk near the battery port. The words "Lithium 3V" are on the face.
    • Disconnect the battery from the metallic fasteners using the tweezers.
    • Slightly bend the fasteners away from the battery.
    • Pick up the battery with the tweezers and dislodge from the fasteners.
  6. HP Pavilion dm4-1265dx Clock Battery Replacement: adım 6, 1 resimden 1.
    • Fully remove battery from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Isaiah Timbers
171 İtibar
1 Kılavuz yazıldı
Ekip
Casper College, Team 1-1, Lareau Spring 2022 Casper College, Team 1-1, Lareau Spring 2022 üyesi
CASC-LAREAU-S22S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 376
