Ana içeriğe geç
HP Pavilion dm4-1265dx Wi-Fi Card Replacement
Neye ihtiyacın var
  1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 2, 3 resimden 1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 2, 3 resimden 2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 2, 3 resimden 3.
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: adım 3, 2 resimden 1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: adım 3, 2 resimden 2.
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 4, 3 resimden 1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 4, 3 resimden 2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 4, 3 resimden 3.
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: adım 5, 3 resimden 1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: adım 5, 3 resimden 2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using ESD safe tweezers, gently disconnect the black and white wires connecting the Wi-Fi card to the device.
    • Move the wires out of the way to allow the Wi-Fi card to spring up without obstructions.
  6. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 6, 2 resimden 1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 6, 2 resimden 2.
    • Remove the two 3.0 mm screws from the Wi-Fi card using a Phillips #0 screwdriver.
  7. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 7, 3 resimden 1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 7, 3 resimden 2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: adım 7, 3 resimden 3.
    • The Wi-Fi card will spring upwards.
    • Gently remove the Wi-Fi card by pulling it away from its socket.
Sonuç
Mason Hall
231 İtibar
2 adet Kılavuz yazıldı
Ekip
Casper College, Team 1-1, Lareau Spring 2022 Casper College, Team 1-1, Lareau Spring 2022 üyesi
CASC-LAREAU-S22S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 237
