Ana içeriğe geç
HP Pavilion dv1000 Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion dv1000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Keyboard Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over.
  3. HP Pavilion dv1000 Keyboard Replacement: adım 3, 2 resimden 1. HP Pavilion dv1000 Keyboard Replacement: adım 3, 2 resimden 2.
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Keyboard Replacement: adım 4, 3 resimden 1. HP Pavilion dv1000 Keyboard Replacement: adım 4, 3 resimden 2. HP Pavilion dv1000 Keyboard Replacement: adım 4, 3 resimden 3.
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Keyboard Replacement, Keyboard: adım 5, 1 resimden 1.
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Keyboard Replacement: adım 6, 2 resimden 1. HP Pavilion dv1000 Keyboard Replacement: adım 6, 2 resimden 2.
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler Latour
266 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 üyesi
UMASSD-VIJAYBHASKAR-S14S6G7
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 1,673
