Ana içeriğe geç
HP Pavilion dv1000 Media Keys Replacement
Neye ihtiyacın var
  1. HP Pavilion dv1000 Media Keys Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Media Keys Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over.
  3. HP Pavilion dv1000 Media Keys Replacement: adım 3, 2 resimden 1. HP Pavilion dv1000 Media Keys Replacement: adım 3, 2 resimden 2.
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Media Keys Replacement: adım 4, 3 resimden 1. HP Pavilion dv1000 Media Keys Replacement: adım 4, 3 resimden 2. HP Pavilion dv1000 Media Keys Replacement: adım 4, 3 resimden 3.
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Media Keys Replacement, Keyboard: adım 5, 1 resimden 1.
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Media Keys Replacement: adım 6, 2 resimden 1. HP Pavilion dv1000 Media Keys Replacement: adım 6, 2 resimden 2.
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
  7. HP Pavilion dv1000 Media Keys Replacement, Media Keys: adım 7, 1 resimden 1.
    • Turn the laptop upside-down again.
  8. HP Pavilion dv1000 Media Keys Replacement: adım 8, 2 resimden 1. HP Pavilion dv1000 Media Keys Replacement: adım 8, 2 resimden 2.
    • Turn the laptop right-side up. Open the screen and tilt it all the way back.
    • Locate the media keys.
    • Gently lift up the media key strip using the plastic pry tool.
    • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler Latour
266 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 üyesi
UMASSD-VIJAYBHASKAR-S14S6G7
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 641
