Ana içeriğe geç
HP Pavilion dv1000 RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion dv1000 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 RAM Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over.
  3. HP Pavilion dv1000 RAM Replacement: adım 3, 2 resimden 1. HP Pavilion dv1000 RAM Replacement: adım 3, 2 resimden 2.
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 RAM Replacement: adım 4, 3 resimden 1. HP Pavilion dv1000 RAM Replacement: adım 4, 3 resimden 2. HP Pavilion dv1000 RAM Replacement: adım 4, 3 resimden 3.
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
    I bought it old but its camera & bluetooth is not working what can be done
    jagannath dey - Yanıt
  5. HP Pavilion dv1000 RAM Replacement, RAM: adım 5, 1 resimden 1.
    • Locate RAM access door on the bottom side of the laptop.
  6. HP Pavilion dv1000 RAM Replacement: adım 6, 3 resimden 1. HP Pavilion dv1000 RAM Replacement: adım 6, 3 resimden 2. HP Pavilion dv1000 RAM Replacement: adım 6, 3 resimden 3.
    • Locate the two screws holding down the RAM access cover
    • Unscrew the two screws with a size 00 Philips screwdriver.
    • Note: The screws do not detach from the cover.
  7. HP Pavilion dv1000 RAM Replacement: adım 7, 2 resimden 1. HP Pavilion dv1000 RAM Replacement: adım 7, 2 resimden 2.
    • Lift up on the screw side of the RAM access cover to remove it.
  8. HP Pavilion dv1000 RAM Replacement: adım 8, 2 resimden 1. HP Pavilion dv1000 RAM Replacement: adım 8, 2 resimden 2.
    • Gently pull apart the metal tabs located on both sides of the stick of RAM.
    • The RAM stick should tilt upwards.
  9. HP Pavilion dv1000 RAM Replacement: adım 9, 1 resimden 1.
    • Gently lift the the RAM up and out of its seat.
  10. HP Pavilion dv1000 RAM Replacement: adım 10, 1 resimden 1.
    • Repeat the previous two steps for the remaining stick of RAM.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Henry OBrien
104 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-37, Forte Spring 2011 Cal Poly, Team 10-37, Forte Spring 2011 üyesi
CPSU-FORTE-S11S10G37
5 Üyeler
9 adet Kılavuz yazıldı
2 Yorum
THANKS - YOU'RE AWESOME!!!! Removing the hard drive was the fix it! the HP site never tells you this - imagine.......
marena - Yanıt
I had never dealt with laptop ram before and i used this guide sussusfully to remove the ram from my old HP Pavilliondv6-3055dx laptop. Thanks!
Andrew Lonero - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 8,886
