Ana içeriğe geç
HP Pavilion dv2000 Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion dv2000 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. HP Pavilion dv2000 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Remove the ten 8.9mm screws (underneath where the battery would be) holding the keyboard and bezel in place.
  2. HP Pavilion dv2000 Keyboard Replacement: adım 2, 2 resimden 1. HP Pavilion dv2000 Keyboard Replacement: adım 2, 2 resimden 2.
    • Flip the computer over to the front (keyboard-side up).
    • Gently pop the bezel off by reaching underneath it and pulling up.
    • If you are doing this for the first time, the bezel may require you to exert a little bit more force to remove it.
  3. HP Pavilion dv2000 Keyboard Replacement: adım 3, 2 resimden 1. HP Pavilion dv2000 Keyboard Replacement: adım 3, 2 resimden 2.
    • The keyboard is held in by three small tabs near the bezel of the computer. Lifting the bezel frees the three tabs.
    • If you are removing the keyboard, the tabs will require a bit more upward force to pull away from the keyboard.
    • Remove the ribbon connecting the keyboard to the computer by pulling back on the ribbon (away from the track pad).
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Erik Muniz
820 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-3, Bruce Fall 2014 CSU Fullerton, Team 2-3, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S2G3
3 Üyeler
Bir Yorum
Many THANKS Erik
I am a computer imbecile. I own a hp pavilion dv2000 that is about 10-12 years old.
I may now be able to FIX it and not have to buy a whole new one
phillip james
Phillip James - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 2,754
