Ana içeriğe geç
HP Pavilion dv2700 Camera Module Replacement
Neye ihtiyacın var
  1. HP Pavilion dv2700 Camera Module Replacement, Camera Module: adım 1, 1 resimden 1.
    • Disconnect device from power source and power down.
    • Disconnect any other external devices.
  2. HP Pavilion dv2700 Camera Module Replacement: adım 2, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 2, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 2, 3 resimden 3.
    • Flip the laptop over so that the bottom is facing upwards.
    • Use your index finger to push the battery latch.
    • Pivot the battery upward and lift it out of the socket to remove it.
  3. HP Pavilion dv2700 Camera Module Replacement: adım 3, 1 resimden 1.
    • Flip the laptop right side up.
    • Open it as wide as the hinge allows it to.
  4. HP Pavilion dv2700 Camera Module Replacement: adım 4, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 4, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 4, 3 resimden 3.
    • Use an opening tool to remove the four rubber screw covers located across the top of the bezel.
    • Remove the Phillips PM2.5×5.0 screws.
    • Remove the two rubber screw covers located at the bottom left and right of the bezel.
  5. HP Pavilion dv2700 Camera Module Replacement: adım 5, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 5, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 5, 3 resimden 3.
    • Flex the inside edges of the left and right sides and the top edge of the display bezel.
    • Lift the bezel with your finger until it disengages from the display enclosure.
  6. HP Pavilion dv2700 Camera Module Replacement: adım 6, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 6, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 6, 3 resimden 3.
    • Remove the two Phillips PM2.5×4.0 screws that secure camera module.
    • Release the camera module assembly unit by simply pulling it out of the laptop.
  7. HP Pavilion dv2700 Camera Module Replacement: adım 7, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 7, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 7, 3 resimden 3.
    • Disconnect the camera module cable from the camera module itself by pulling it out.
    • Be careful not to break the camera module cable.
    • Turn the module upside down and remove the screws for the camera bracket.
    • Remove the camera module from the bracket.
Sonuç
Kayaen Jardine
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 446
