Ana içeriğe geç
HP Pavilion dv2700 Camera Module Replacement
Neye ihtiyacın var
    1. HP Pavilion dv2700 Camera Module Replacement, Camera Module: adım 1, 1 resimden 1.
      • Disconnect device from power source and power down.
      • Disconnect any other external devices.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion dv2700 Camera Module Replacement: adım 2, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 2, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 2, 3 resimden 3.
      • Flip the laptop over so that the bottom is facing upwards.
      • Use your index finger to push the battery latch.
      • Pivot the battery upward and lift it out of the socket to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion dv2700 Camera Module Replacement: adım 3, 1 resimden 1.
      • Flip the laptop right side up.
      • Open it as wide as the hinge allows it to.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion dv2700 Camera Module Replacement: adım 4, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 4, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 4, 3 resimden 3.
      • Use an opening tool to remove the four rubber screw covers located across the top of the bezel.
      • Remove the Phillips PM2.5×5.0 screws.
      • Remove the two rubber screw covers located at the bottom left and right of the bezel.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion dv2700 Camera Module Replacement: adım 5, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 5, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 5, 3 resimden 3.
      • Flex the inside edges of the left and right sides and the top edge of the display bezel.
      • Lift the bezel with your finger until it disengages from the display enclosure.
      FixBot'a Sor
      Yorum Ekle
    6. HP Pavilion dv2700 Camera Module Replacement: adım 6, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 6, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 6, 3 resimden 3.
      • Remove the two Phillips PM2.5×4.0 screws that secure camera module.
      • Release the camera module assembly unit by simply pulling it out of the laptop.
      FixBot'a Sor
      Yorum Ekle
    7. HP Pavilion dv2700 Camera Module Replacement: adım 7, 3 resimden 1. HP Pavilion dv2700 Camera Module Replacement: adım 7, 3 resimden 2. HP Pavilion dv2700 Camera Module Replacement: adım 7, 3 resimden 3.
      • Disconnect the camera module cable from the camera module itself by pulling it out.
      • Be careful not to break the camera module cable.
      • Turn the module upside down and remove the screws for the camera bracket.
      • Remove the camera module from the bracket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kayaen Jardine
145 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 814
