Ana içeriğe geç
HP Pavilion dv2700 Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion dv2700 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • To remove the battery, pull the tab to the left and lift the battery from the computer.
  2. HP Pavilion dv2700 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
    • The screws cannot be removed from the cover.
    • To remove the cover, lift up and to the left.
  3. HP Pavilion dv2700 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
    • These are the two screws located on the right side of the hard drive.
  4. HP Pavilion dv2700 Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion dv2700 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Lift the tab connected to the hard drive in order to remove it.
    • The hard drive may be difficult to remove by grabbing the tab. In this case, use the spudger to gently pry it from the computer.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jared Opperman
161 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 22-6, Rauch Fall 2015 Texas Tech, Team 22-6, Rauch Fall 2015 üyesi
TTU-RAUCH-F15S22G6
3 Üyeler
2 adet Kılavuz yazıldı
Bir Yorum
Hi, I have a seagate hard drive that was mounted on a hp pavillon dv series computer. I only have the hard disk and I can not find any serial adapter that can be connected to the hard disk connector. I saw on amazon and ebay but I did not find anything. Can you help me? Thank you!
L. S. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 3,009
