Ana içeriğe geç
HP Pavilion dv2913cl Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion dv2913cl Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Locate battery on the bottom of the laptop.
  2. HP Pavilion dv2913cl Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide the battery release bar to the left, this should release the battery so you can then remove it.
  3. HP Pavilion dv2913cl Keyboard Replacement: adım 3, 2 resimden 1. HP Pavilion dv2913cl Keyboard Replacement: adım 3, 2 resimden 2.
    • Locate the three screws for the keyboard by finding the small keyboard picture, remove these screws and flip the laptop back over.
  4. HP Pavilion dv2913cl Keyboard Replacement: adım 4, 1 resimden 1.
    • Open the laptop so the keyboard is facing upwards and towards you.
  5. HP Pavilion dv2913cl Keyboard Replacement: adım 5, 2 resimden 1. HP Pavilion dv2913cl Keyboard Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to get underneath the plastic bar above the keyboard, pry upwards. Pry the keyboard upwards gently.
    • Be careful not to pull the keyboard too hard so you do not rip the silver ribbon cable attached to the laptop.
  6. HP Pavilion dv2913cl Keyboard Replacement: adım 6, 2 resimden 1. HP Pavilion dv2913cl Keyboard Replacement: adım 6, 2 resimden 2.
    • Release the ribbon cable by using a flathead screw driver. Release the two tabs holding the cable and pull outwards.
    • Pull the keyboard up and out from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam Braga
230 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 UMass Dartmouth, Team 2-7, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G7
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 161
