Ana içeriğe geç
HP Pavilion dv4-2045dx Battery Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. HP Pavilion dv4-2045dx Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop and disconnect the power adapter before doing anything else with your computer.
  2. HP Pavilion dv4-2045dx Battery Replacement: adım 2, 1 resimden 1.
    • Turn your laptop over so the bottom of your laptop is facing up and the hinge is located away from you
  3. HP Pavilion dv4-2045dx Battery Replacement: adım 3, 2 resimden 1. HP Pavilion dv4-2045dx Battery Replacement: adım 3, 2 resimden 2.
    • Slide the lock switch to the left.
    • The lock switch is located by the bottom left side of the battery.
    • The battery should pop up after you move the switch.
  4. HP Pavilion dv4-2045dx Battery Replacement: adım 4, 3 resimden 1. HP Pavilion dv4-2045dx Battery Replacement: adım 4, 3 resimden 2. HP Pavilion dv4-2045dx Battery Replacement: adım 4, 3 resimden 3.
    • Lift up the released battery by rotating it up and away from you.
    • Pull the battery out.
    • The battery is held in by a latch in the front of the battery socket and by tabs in the back. When putting the battery back in, line the tabs back up with the grooves located in the back of the socket and rotate the battery towards you. When in place, push the battery in until you hear a click.
Sonuç
Megan Todd
600 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-8, Williams Fall 2015 Baylor, Team 6-8, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G8
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 98
