Giriş
If the hard drive on which your OS is installed fails, you will see a system error screen. If so, you will need to replace your main hard drive.
Neye ihtiyacın var
Locate two 7.5 mm screws on the hard drive case plate.
Use the Phillips #0 screw driver to loosen both 7.5 mm screws.
4 farklı kişi bu kılavuzu tamamladı.
