Ana içeriğe geç
HP Pavilion dv4-4141us RAM Replacement
Neye ihtiyacın var
    1. HP Pavilion dv4-4141us RAM Replacement, RAM: adım 1, 1 resimden 1.
      • Lift up the back panel using a spudger and remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion dv4-4141us RAM Replacement: adım 2, 1 resimden 1.
      • Push the two metal clips away from each other to release the RAM.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion dv4-4141us RAM Replacement: adım 3, 2 resimden 1. HP Pavilion dv4-4141us RAM Replacement: adım 3, 2 resimden 2.
      • Each RAM stick will pop up at a 45 degree angle.
      • Pull the RAM up and away and remove it from the device.
      • Do not use a metal spudger for this step. Incorrect use of the metal spudger can damage the internal components in your device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Vincent Gardner
390 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Sinclaire Fall 2021 UMass Dartmouth, Team 2-3, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G3
3 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 297
