Ana içeriğe geç
HP Pavilion dv4000 RAM Replacement
Neye ihtiyacın var
    1. HP Pavilion dv4000  RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the laptop upside down with the battery compartment facing you.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion dv4000  RAM Replacement: adım 2, 1 resimden 1.
      • Slide the battery release latch to the right and hold in place.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion dv4000  RAM Replacement: adım 3, 1 resimden 1.
      • Lift the front edge of the battery up and remove it from the compartment.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion dv4000  RAM Replacement, RAM: adım 4, 1 resimden 1.
      • Orient the laptop with the memory cover towards you.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion dv4000  RAM Replacement: adım 5, 2 resimden 1. HP Pavilion dv4000  RAM Replacement: adım 5, 2 resimden 2.
      • Unscrew the three 2x5mm screws with a #00 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion dv4000  RAM Replacement: adım 6, 1 resimden 1.
      • Remove the memory cover.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion dv4000  RAM Replacement: adım 7, 1 resimden 1.
      • Pull the two tabs on both sides of the memory stick to release it.
      • The memory should pop up on its own with very little force applied to the tabs.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion dv4000  RAM Replacement: adım 8, 2 resimden 1. HP Pavilion dv4000  RAM Replacement: adım 8, 2 resimden 2.
      • Grab the memory stick from the sides with your fingers and set aside.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chris Marshall
481 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G2
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Hi, how much ram does this laptop support
Sébastien Grant - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 1,515
