Ana içeriğe geç
Giriş
Removing the battery from your laptop is the first thing you should do before doing any repairs on it. Working while the battery is in the machine might cause damage to the circuit boards or shock you.
  1. Turn the laptop upside down with the battery compartment facing you.
    • Turn the laptop upside down with the battery compartment facing you.
  2. Slide the battery release latch to the right and hold in place.
    • Slide the battery release latch to the right and hold in place.
  3. Lift the front edge of the battery up and remove it from the compartment.
    • Lift the front edge of the battery up and remove it from the compartment.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashukang Kima Tabong
222 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
Her zaman: 286
