Ana içeriğe geç
HP Pavilion dv4000 Keyboard Replacement
Neye ihtiyacın var
    1. HP Pavilion dv4000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the laptop upside down with the battery compartment facing you.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion dv4000 Keyboard Replacement: adım 2, 1 resimden 1.
      • Slide the battery release latch to the right and hold in place.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion dv4000 Keyboard Replacement: adım 3, 1 resimden 1.
      • Lift the front edge of the battery up and remove it from the compartment.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion dv4000 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
      • Have your device open in front of you for easy access to the keyboard.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion dv4000 Keyboard Replacement: adım 5, 1 resimden 1.
      • Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
      • Be careful not to damage any components with the tool while prying.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion dv4000 Keyboard Replacement: adım 6, 1 resimden 1.
      • Lift the plastic piece up.
      • When lifting this piece, be careful not to damage the ribbon strip connected to it.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion dv4000 Keyboard Replacement: adım 7, 3 resimden 1. HP Pavilion dv4000 Keyboard Replacement: adım 7, 3 resimden 2. HP Pavilion dv4000 Keyboard Replacement: adım 7, 3 resimden 3.
      • Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
      • Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
      • Remove plastic piece and set aside.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion dv4000 Keyboard Replacement: adım 8, 1 resimden 1.
      • Locate the four 2x2 mm screws that hold the keyboard in place.
      FixBot'a Sor
      Yorum Ekle
    6. HP Pavilion dv4000 Keyboard Replacement: adım 9, 1 resimden 1.
      • Unscrew the four 2x2 mm screws with a #00 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    7. HP Pavilion dv4000 Keyboard Replacement: adım 10, 2 resimden 1. HP Pavilion dv4000 Keyboard Replacement: adım 10, 2 resimden 2.
      • Lift the keyboard up.
      • When lifting the keyboard, be sure not to damage the ribbon strip that is connected to it.
      FixBot'a Sor
      Yorum Ekle
    8. HP Pavilion dv4000 Keyboard Replacement: adım 11, 1 resimden 1.
      • Locate where the ribbon strip is connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    9. HP Pavilion dv4000 Keyboard Replacement: adım 12, 2 resimden 1. HP Pavilion dv4000 Keyboard Replacement: adım 12, 2 resimden 2.
      • Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
      • Be careful during this step as these clips are very easy to break.
      FixBot'a Sor
      Yorum Ekle
    10. HP Pavilion dv4000 Keyboard Replacement: adım 13, 3 resimden 1. HP Pavilion dv4000 Keyboard Replacement: adım 13, 3 resimden 2. HP Pavilion dv4000 Keyboard Replacement: adım 13, 3 resimden 3.
      • Remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick LaMarche
373 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 1,263
