Ana içeriğe geç
HP Pavilion dv4000 Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion dv4000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Keyboard Replacement: adım 3, 1 resimden 1.
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Have your device open in front of you for easy access to the keyboard.
  5. HP Pavilion dv4000 Keyboard Replacement: adım 5, 1 resimden 1.
    • Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
    • Be careful not to damage any components with the tool while prying.
  6. HP Pavilion dv4000 Keyboard Replacement: adım 6, 1 resimden 1.
    • Lift the plastic piece up.
    • When lifting this piece, be careful not to damage the ribbon strip connected to it.
  7. HP Pavilion dv4000 Keyboard Replacement: adım 7, 3 resimden 1. HP Pavilion dv4000 Keyboard Replacement: adım 7, 3 resimden 2. HP Pavilion dv4000 Keyboard Replacement: adım 7, 3 resimden 3.
    • Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
    • Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
    • Remove plastic piece and set aside.
  8. HP Pavilion dv4000 Keyboard Replacement: adım 8, 1 resimden 1.
    • Locate the four 2x2 mm screws that hold the keyboard in place.
  9. HP Pavilion dv4000 Keyboard Replacement: adım 9, 1 resimden 1.
    • Unscrew the four 2x2 mm screws with a #00 Phillips screwdriver.
  10. HP Pavilion dv4000 Keyboard Replacement: adım 10, 2 resimden 1. HP Pavilion dv4000 Keyboard Replacement: adım 10, 2 resimden 2.
    • Lift the keyboard up.
    • When lifting the keyboard, be sure not to damage the ribbon strip that is connected to it.
  11. HP Pavilion dv4000 Keyboard Replacement: adım 11, 1 resimden 1.
    • Locate where the ribbon strip is connected to the motherboard.
  12. HP Pavilion dv4000 Keyboard Replacement: adım 12, 2 resimden 1. HP Pavilion dv4000 Keyboard Replacement: adım 12, 2 resimden 2.
    • Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
    • Be careful during this step as these clips are very easy to break.
  13. HP Pavilion dv4000 Keyboard Replacement: adım 13, 3 resimden 1. HP Pavilion dv4000 Keyboard Replacement: adım 13, 3 resimden 2. HP Pavilion dv4000 Keyboard Replacement: adım 13, 3 resimden 3.
    • Remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick LaMarche
373 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 893
