Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will show you how to remove the keyboard, in case you need to replace it.
Neye ihtiyacın var
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Remove the two 11.0mm screws at the corners on either side of the battery compartment.
Remove the three 6.0mm screws.
Remove the two 5.0mm screws.
Remove the 6.0mm screw in the middle of the battery compartment.
6 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Hey is keyboard replacement same or very similiar procedure with hp dv8000?
Brilliant. This is the best tutorial out there. Many thanks indeed!!!!
