Ana içeriğe geç
HP Pavilion dv5000 Optical Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion dv5000 Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Optical Drive Replacement, RAM Cover: adım 2, 3 resimden 1. HP Pavilion dv5000 Optical Drive Replacement, RAM Cover: adım 2, 3 resimden 2. HP Pavilion dv5000 Optical Drive Replacement, RAM Cover: adım 2, 3 resimden 3.
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 Optical Drive Replacement, Optical Drive: adım 3, 1 resimden 1.
    • Remove the 11.0mm screw securing the optical drive to the computer.
  4. HP Pavilion dv5000 Optical Drive Replacement: adım 4, 3 resimden 1. HP Pavilion dv5000 Optical Drive Replacement: adım 4, 3 resimden 2. HP Pavilion dv5000 Optical Drive Replacement: adım 4, 3 resimden 3.
    • Locate the optical drive. The optical drive is located on the left side of the RAM bay.
    • Press the exposed edge of the optical drive gently with the spudger until the drive releases from the computer frame.
    • Pull the optical drive completely out of the computer frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Kwok
271 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G34
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,620
