Ana içeriğe geç
HP Pavilion dv5000 RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion dv5000 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 RAM Replacement, RAM Cover: adım 2, 3 resimden 1. HP Pavilion dv5000 RAM Replacement, RAM Cover: adım 2, 3 resimden 2. HP Pavilion dv5000 RAM Replacement, RAM Cover: adım 2, 3 resimden 3.
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Release the RAM by pressing the metal heads of the RAM clips to the sides. Use tweezers and the spudger to spread the clips until they are completely off the RAM.
    • There are two RAM cards in this device.
  4. HP Pavilion dv5000 RAM Replacement: adım 4, 3 resimden 1. HP Pavilion dv5000 RAM Replacement: adım 4, 3 resimden 2. HP Pavilion dv5000 RAM Replacement: adım 4, 3 resimden 3.
    • Remove the RAM.
  5. HP Pavilion dv5000 RAM Replacement: adım 5, 1 resimden 1.
    • As in step 3, press the clips on both sides to release the second RAM clip.
  6. HP Pavilion dv5000 RAM Replacement: adım 6, 3 resimden 1. HP Pavilion dv5000 RAM Replacement: adım 6, 3 resimden 2. HP Pavilion dv5000 RAM Replacement: adım 6, 3 resimden 3.
    • Remove the RAM.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Thanh Nguyen
399 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G34
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 15,022
