Ana içeriğe geç
HP Pavilion dv5000 RTC Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion dv5000 RTC Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: adım 2, 3 resimden 1. HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: adım 2, 3 resimden 2. HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: adım 2, 3 resimden 3.
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 RTC Battery Replacement, Wifi Card: adım 3, 2 resimden 1. HP Pavilion dv5000 RTC Battery Replacement, Wifi Card: adım 3, 2 resimden 2.
    • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
  4. HP Pavilion dv5000 RTC Battery Replacement: adım 4, 2 resimden 1. HP Pavilion dv5000 RTC Battery Replacement: adım 4, 2 resimden 2.
    • Remove the two 6.0mm Phillips screws from the wifi card.
    • Remove the wifi card.
  5. HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: adım 5, 3 resimden 1. HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: adım 5, 3 resimden 2. HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: adım 5, 3 resimden 3.
    • Remove the RTC Battery from the battery holder.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Farid Khoshnevissan
820 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G34
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 45
Her zaman: 12,051
