Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Turn off the computer, and unplug it from all external power sources.
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. Remove the two 11.0mm screws at the corners on either side of the battery compartment. (shown by the red circles)
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment. (shown by the red circles)
    • Remove the three 6.0mm screws. (shown by the blue circles)
    • Remove the two silver 5.0mm screws. (shown by the yellow circles)
    • Remove the 6.0mm screw in the middle of the battery compartment. (shown by the teal circle)
  3. Lift plastic covering strip gently at the corner to separate the plastic it from the keyboard area. Slide a plastic separator tool along the strip and lift off to remove it. Slide a plastic separator tool along the strip and lift off to remove it.
    • Lift plastic covering strip gently at the corner to separate the plastic it from the keyboard area.
    • Slide a plastic separator tool along the strip and lift off to remove it.
  4. Using tweezers, remove the (8) silicone covers over the screws of the screen's frame. The image still shows the plastic strip that was removed in the last step Remove the (8) now-exposed screws.
    • Using tweezers, remove the (8) silicone covers over the screws of the screen's frame.
    • The image still shows the plastic strip that was removed in the last step
    • Remove the (8) now-exposed screws.
  5. Using the plastic separator, make your way up from the bottom, separating the screen's frame off. You may need to finagle the locking tab slightly in order to pull the frame away from it You may need to finagle the locking tab slightly in order to pull the frame away from it
    • Using the plastic separator, make your way up from the bottom, separating the screen's frame off.
    • You may need to finagle the locking tab slightly in order to pull the frame away from it
  6. With frame removed, the locking assembly is visible Using tweezers, pull the spring off the hook, and the locking assembly will pull down and off with little effort Be sure not to drop the spring behind the screen while removing it!
    • With frame removed, the locking assembly is visible
    • Using tweezers, pull the spring off the hook, and the locking assembly will pull down and off with little effort
    • Be sure not to drop the spring behind the screen while removing it!
  7. Congratulations! You're ready to install the new assembly and reassemble your laptop!
    • Congratulations! You're ready to install the new assembly and reassemble your laptop!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Thomas Leman
234 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 4-5, Calaway Spring 2014 UMass Dartmouth, Team 4-5, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S4G5
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 635
