Parçalar
Hiçbir parçaya gerek yok.
Shut the screen, and lay the computer face-down on a flat, sturdy surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image. Sliding this switch from right to left will release the battery.
Remove the battery.
Remove the two 5mm screws securing the right side of the RAM cover to the computer frame.
Lift the right side of the RAM cover to remove.
The wifi card is connected to the computer with the two antenna lead wires.
Remove the two 11.0mm screws at the corners on either side of the battery compartment.
Remove the three 6.0mm screws.
Remove the two 5.0mm screws.
Remove the 6.0mm screw in the middle of the battery compartment.
Use the plastic prying tool to disconnect the screen cable from the system board.
2 başka kişi bu kılavuzu tamamladı.
Bir Yorum
To reinstall the PCI WIRES I'm finding no other way to reattach them except by removing the outer cover AND RE-ATTACHING. . I will finish-up the repair and send you my results
