Neye ihtiyacın var
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Remove the two 5mm Phillips screws on the right side of the RAM cover.
Lift the right side of the RAM cover, and remove it.
Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
The white wire connects to the AUX terminal.
The black wire connects to the MAIN terminal.
Remove the two 11.0mm screws at the corners on either side of the battery compartment.
Remove the three 6.0mm screws.
Remove the two 5.0mm screws.
Remove the 6.0mm screw in the middle of the battery compartment.
Use the plastic prying tool to disconnect the screen cable from the system board.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
To reinstall the PCI WIRES I'm finding no other way to reattach them except by removing the outer cover AND RE-ATTACHING. . I will finish-up the repair and send you my results
