Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Unplug the charger and remove the battery.
    • Unplug the charger and remove the battery.
  2. Flip over the laptop.
    • Flip over the laptop.
  3. Remove the Hard Drive cover screws with a Phillips #1 screwdriver.
    • Remove the Hard Drive cover screws with a Phillips #1 screwdriver.
    • The screws will not come all the way out
  4. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  5. Remove the Hard Drive cover.
    • Remove the Hard Drive cover.
  6. Remove the SATA cable from the hard drive, then remove the hard drive.
    • Remove the SATA cable from the hard drive, then remove the hard drive.
  7. Remove the screws from the hard drive enclosure. Remove the screws from the hard drive enclosure.
    • Remove the screws from the hard drive enclosure.
  8. Remove the Hard Drive from the enclosure
    • Remove the Hard Drive from the enclosure
  9. Insert the new hard drive in enclosure.
    • Insert the new hard drive in enclosure.
  10. Install an OS on the hard drive.
    • Install an OS on the hard drive.
    • For this system, Windows is recommended.
    • Do not install a version of Windows that is not supported if this system is going to be connected to the internet, use a supported version, such as 8.1 or 10.
Sonuç
Jonathan M.
371 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 147
