Ana içeriğe geç
HP Pavilion dv6-1245dx RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6-1245dx RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Shut down the computer and unplug it from the outlet.
    • All screws removed in this guide will require a Phillips #00 screwdriver.
  2. HP Pavilion dv6-1245dx RAM Replacement: adım 2, 1 resimden 1.
    • Turn the computer upside down.
  3. HP Pavilion dv6-1245dx RAM Replacement: adım 3, 1 resimden 1.
    • Loosen the three screws from the memory module compartment cover
    • Screws will not come all the way out.
  4. HP Pavilion dv6-1245dx RAM Replacement: adım 4, 1 resimden 1.
    • Remove the memory module compartment cover.
  5. HP Pavilion dv6-1245dx RAM Replacement: adım 5, 3 resimden 1. HP Pavilion dv6-1245dx RAM Replacement: adım 5, 3 resimden 2. HP Pavilion dv6-1245dx RAM Replacement: adım 5, 3 resimden 3.
    • Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
    • Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
    • If you are replacing both memory cards, repeat this step with the bottom memory card.
  6. HP Pavilion dv6-1245dx RAM Replacement: adım 6, 1 resimden 1.
    • To replace the memory card, insert the card at a 45-degree angle, then push into slot.
    • Push down gently so the silver retaining tabs click back into place.
    • If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jaime
562 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 2,375
