Ana içeriğe geç
HP Pavilion dv6-2158nr Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6-2158nr Hard Drive Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion dv6-2158nr Hard Drive Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion dv6-2158nr Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 1. HP Pavilion dv6-2158nr Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 2. HP Pavilion dv6-2158nr Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer.
    • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
  3. HP Pavilion dv6-2158nr Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion dv6-2158nr Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use the Mylar tab to lift the hard drive up, and then slide out to release it from the hard drive bay.
  4. HP Pavilion dv6-2158nr Hard Drive Replacement: adım 4, 3 resimden 1. HP Pavilion dv6-2158nr Hard Drive Replacement: adım 4, 3 resimden 2. HP Pavilion dv6-2158nr Hard Drive Replacement: adım 4, 3 resimden 3.
    • Disconnect the hard drive cable from the system board.
    • Remove four 4mm screws from the hard drive case.
    • There are two screws on each side of the hard drive.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chad
1.123 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-34, Maness Winter 2014 Cal Poly, Team 10-34, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G34
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 3,034
