Ana içeriğe geç
HP Pavilion dv6-2158nr RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6-2158nr RAM Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion dv6-2158nr RAM Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion dv6-2158nr RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr RAM Replacement, RAM: adım 2, 1 resimden 1.
    • Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
  3. HP Pavilion dv6-2158nr RAM Replacement: adım 3, 3 resimden 1. HP Pavilion dv6-2158nr RAM Replacement: adım 3, 3 resimden 2. HP Pavilion dv6-2158nr RAM Replacement: adım 3, 3 resimden 3.
    • Remove cover and expose the memory module by lifting the cover up like its on a hinge.
  4. HP Pavilion dv6-2158nr RAM Replacement: adım 4, 3 resimden 1. HP Pavilion dv6-2158nr RAM Replacement: adım 4, 3 resimden 2. HP Pavilion dv6-2158nr RAM Replacement: adım 4, 3 resimden 3.
    • Locate the release tabs on both sides of the RAM.
    • Use non-conductive pointing tool or fingers to prevent static build up and damaging components.
    • Pull the metal tabs away from the memory to release it.
    • Pull RAM away from clips to remove from device
    • Repeat for second RAM if necessary
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chad
1.123 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-34, Maness Winter 2014 Cal Poly, Team 10-34, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G34
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,538
