Giriş
The random access memory (RAM) stores temporary data for programs to use while they are running. Some programs use a lot of memory so it may be useful to replace RAM with ones with more memory on them.
Neye ihtiyacın var
Locate the battery on the bottom side of the laptop.
Slide the release switch and the battery will pop out.
Remove the battery
Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
Bir başkası bu kılavuzu tamamladı.
