Giriş
Is the CD drive not opening anymore? Maybe it broke while you had it open and now you can't get it to close. This guide will walk you through replacing it with a new, working optical drive, with only a spudger and a Phillips #0 screw driver. Once you have a clean work space and the tools required, follow the steps below.
Neye ihtiyacın var
Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
