Ana içeriğe geç
HP Pavilion dv6-6117dx RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: adım 1, 2 resimden 1. HP Pavilion dv6-6117dx RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: adım 2, 2 resimden 1. HP Pavilion dv6-6117dx RAM Replacement: adım 2, 2 resimden 2.
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: adım 3, 3 resimden 1. HP Pavilion dv6-6117dx RAM Replacement: adım 3, 3 resimden 2. HP Pavilion dv6-6117dx RAM Replacement: adım 3, 3 resimden 3.
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: adım 4, 2 resimden 1. HP Pavilion dv6-6117dx RAM Replacement: adım 4, 2 resimden 2.
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: adım 5, 2 resimden 1. HP Pavilion dv6-6117dx RAM Replacement: adım 5, 2 resimden 2.
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
Sonuç
Joshua Holme
765 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 UMass Dartmouth, Team S6-G3, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 737
