Giriş
Are you unable to connect to WiFi? Your WiFi adapter may be broken. This guide will walk you through replacing it with a new, working WiFi adapter, with only a spudger and a Phillips #0 screw driver. Once you have a clean work space and the tools required, follow the steps below.
Neye ihtiyacın var
Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
2 farklı kişi bu kılavuzu tamamladı.
