Ana içeriğe geç
HP Pavilion dv6-6117dx WiFi Adapter Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: adım 1, 2 resimden 1. HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: adım 1, 2 resimden 2.
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 2, 2 resimden 1. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 2, 2 resimden 2.
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 3, 3 resimden 1. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 3, 3 resimden 2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 3, 3 resimden 3.
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 4, 3 resimden 1. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 4, 3 resimden 2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 4, 3 resimden 3.
    • Using a spudger, remove the white and black antenna wires from the WiFi Adapter
    • When connecting these wires later, line up the connector and press straight down until you feel them snap in place.
  5. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 5, 3 resimden 1. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 5, 3 resimden 2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 5, 3 resimden 3.
    • Using a Phillips #0 screw driver, remove the two 4mm screws holding the WiFi adapter in place
    • After the screws are removed the WiFi Adapter will raise to a 45º angle.
  6. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 6, 2 resimden 1. HP Pavilion dv6-6117dx WiFi Adapter Replacement: adım 6, 2 resimden 2.
    • Always handle the WiFi Adapter by the edges to avoid damaging the part.
    • Pull the WiFi Adapter out of the slot at a 45º angle.
    • When inserting the new WiFi Adapter, you should insert it at this same angle.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joshua Holme
765 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 UMass Dartmouth, Team S6-G3, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G3
3 Üyeler
Bir Yorum
Thanks i need to replace the wifi adapter in an old pc of mine,looks pretty simple.
pturner14 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 2,351
