Ana içeriğe geç
HP Pavilion dv6-6180us Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6-6180us Hard Drive  Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Hard Drive  Replacement: adım 2, 1 resimden 1.
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Hard Drive  Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Hard Drive  Replacement: adım 4, 1 resimden 1.
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Hard Drive  Replacement: adım 5, 1 resimden 1.
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Hard Drive  Replacement: adım 6, 1 resimden 1.
    • Unplug the hard drive wire to detach the hard drive.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
michelle pulido
859 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-2, Bruce Fall 2016 CSU Fullerton, Team 1-2, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,796
