Ana içeriğe geç
HP Pavilion dv6-6180us Speaker Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6-6180us Speaker Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Speaker Replacement: adım 2, 1 resimden 1.
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Speaker Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Speaker Replacement: adım 4, 1 resimden 1.
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Speaker Replacement: adım 5, 1 resimden 1.
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Speaker Replacement: adım 6, 1 resimden 1.
    • Unplug the hard drive wire to detach the hard drive.
  7. HP Pavilion dv6-6180us Speaker Replacement, Speaker: adım 7, 1 resimden 1.
    • Unscrew four 3.5 mm screws from the inside of the battery compartment with PH 1 screwdriver.
    • Unscrew nine 5 mm screws with PH 1 screwdriver.
    • Unscrew four 4 mm screws with PH 1 screwdriver.
  8. HP Pavilion dv6-6180us Speaker Replacement: adım 8, 1 resimden 1.
    • Flip right-side up and open the laptop.
    • Pry open the keyboard using plastic opening tool starting from the top.
    • Lift up keyboard gently,as a silver ribbon is still attaching it to the laptop
  9. HP Pavilion dv6-6180us Speaker Replacement: adım 9, 1 resimden 1.
    • Place keyboard upside down.
    • Lift up plastic cover over keyboard ribbon cable.
    • Pull ribbon cable up away from keyboard to completely remove.
  10. HP Pavilion dv6-6180us Speaker Replacement: adım 10, 1 resimden 1.
    • Remove seven 4mm pannel screws with PH 1 screwdriver.
  11. HP Pavilion dv6-6180us Speaker Replacement: adım 11, 1 resimden 1.
    • Put the computer on its side
    • Separate top panel from bottom frame.
  12. HP Pavilion dv6-6180us Speaker Replacement: adım 12, 1 resimden 1.
    • Pop open palm rest panel.
  13. HP Pavilion dv6-6180us Speaker Replacement: adım 13, 1 resimden 1.
    • Pull ribbon to detach from bottom panel.
  14. HP Pavilion dv6-6180us Speaker Replacement: adım 14, 2 resimden 1. HP Pavilion dv6-6180us Speaker Replacement: adım 14, 2 resimden 2.
    • Lift up speaker.
  15. HP Pavilion dv6-6180us Speaker Replacement: adım 15, 1 resimden 1.
    • Lift up white panel covering speaker ribbon cable.
  16. HP Pavilion dv6-6180us Speaker Replacement: adım 16, 1 resimden 1.
    • Pull out the speaker ribbon.
  17. HP Pavilion dv6-6180us Speaker Replacement: adım 17, 2 resimden 1. HP Pavilion dv6-6180us Speaker Replacement: adım 17, 2 resimden 2.
    • Unhook speaker cable from hooks.
  18. HP Pavilion dv6-6180us Speaker Replacement: adım 18, 1 resimden 1.
    • Pull out silver wire to reveal black speaker wire.
  19. HP Pavilion dv6-6180us Speaker Replacement: adım 19, 1 resimden 1.
    • Unplug the red, white, and black speaker wire connector.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
michelle pulido
859 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-2, Bruce Fall 2016 CSU Fullerton, Team 1-2, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 2,530
