Ana içeriğe geç
HP Pavilion dv6000 Camera Replacement
  1. HP Pavilion dv6000 Camera Replacement, Camera: adım 1, 2 resimden 1. HP Pavilion dv6000 Camera Replacement, Camera: adım 1, 2 resimden 2.
    • Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
    • If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 Camera Replacement: adım 2, 3 resimden 1. HP Pavilion dv6000 Camera Replacement: adım 2, 3 resimden 2. HP Pavilion dv6000 Camera Replacement: adım 2, 3 resimden 3.
    • Press the tabs in on the sides of the screen and pop the plastic covering off.
    • The edges of the LCD screen are very sharp. Take care to not cut your fingers!
  3. HP Pavilion dv6000 Camera Replacement: adım 3, 1 resimden 1.
    • Lift the screen out of the casing at the top near the camera.
    • Take care to not snap the plastic casing! It is brittle and still attached to the bottom of the screen.
  4. HP Pavilion dv6000 Camera Replacement: adım 4, 1 resimden 1.
    • Gently remove the main cable from the camera.
  5. HP Pavilion dv6000 Camera Replacement: adım 5, 2 resimden 1. HP Pavilion dv6000 Camera Replacement: adım 5, 2 resimden 2.
    • There are three clasps holding the camera down. Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings).
    • The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
  6. HP Pavilion dv6000 Camera Replacement: adım 6, 1 resimden 1.
    • Remove the camera unit from the laptop and you are done!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ben Hirsch
3.826 İtibar
10 adet Kılavuz yazıldı
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G33
4 Üyeler
12 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 9,869
