Giriş
Replace the optical drive assembly in your HP Pavilion dv6000.
Parçalar
Hiçbir parçaya gerek yok.
  1. Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
    • Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
    • Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
  2. Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
    • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
    • The tray will partially pop out of the laptop.
    • Firmly pull the drive straight away from the laptop.
    • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
    • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
  3. Remove the three 3.2 mm screws securing the top plate of the optical drive. Lift and remove the top plate up off the optical drive.
    • Remove the three 3.2 mm screws securing the top plate of the optical drive.
    • Lift and remove the top plate up off the optical drive.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Lift and remove the optical drive assembly.
    • Lift and remove the optical drive assembly.
    • It may be helpful to gently "rock" the drive assembly side to side to dislodge it from its recess.
    • For the rest of the guide, be careful to not touch any of the circuitry on the board as well as the laser lens!
  6. Flip the drive over.
    • Flip the drive over.
    • Pull the small ribbon cable straight away from its socket on the optical drive assembly board.
  7. Use your fingernail to flip up the cable retaining flap on the ZIF socket for the larger ribbon cable.
    • Use your fingernail to flip up the cable retaining flap on the ZIF socket for the larger ribbon cable.
    • Pull the larger ribbon cable straight out of its socket on the optical drive assembly board.
  8. Lift and remove the optical drive assembly from the optical drive framework.
    • Lift and remove the optical drive assembly from the optical drive framework.
    • Optical drive assembly remains.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ben Hirsch
3.670 İtibar
10 adet Kılavuz yazıldı
Takım
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G33
4 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 2
Son 30 Gün: 18
Her zaman: 6,597
