Giriş
If you need more memory because your computer is running slowly, or you are having memory problems, the RAM is very easy to replace in the HP Pavilion dv6000.
Remove the two screws from the memory shield and lift up. The screws will remain into the shield
18 farklı kişi bu kılavuzu tamamladı.
3 Comments
if you have bios version f.25 or newer you can have up to 4gb of ram
2+2 or 4+4 ? which one?
That is pretty helpful. I think I am going to update my bios, not to mention the article forgot to mention to have a DDR2 ram. Just make sure to look for a DDR2 PC2- 5300 version with 667 MHz.
Tommy E. -
