Ana içeriğe geç
HP Pavilion dv6000 Wireless Card Replacement
  1. HP Pavilion dv6000 Wireless Card Replacement, Wireless Card: adım 1, 1 resimden 1.
    • Lay the laptop on a flat surface, battery side up.
    • Remove the two screws securing the RAM shield to the lower case.
    • The screws will remain captive within the shield.
    • Lift and remove the RAM shield up from the lower case.
  2. HP Pavilion dv6000 Wireless Card Replacement: adım 2, 2 resimden 1. HP Pavilion dv6000 Wireless Card Replacement: adım 2, 2 resimden 2.
    • Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card.
    • Be careful to pull on the contacts and not the wires. The crimps used to hold them to the wires are delicate.
  3. HP Pavilion dv6000 Wireless Card Replacement: adım 3, 1 resimden 1.
    • Remove the two 3.7 mm Phillips screws securing the wireless card to the motherboard.
    • Upon removing the Phillips screws that secures the wireless card to the motherboard, the wireless card board should pop up from its top side.
    • Grasp the wireless card and pull it straight out of its socket on the motherboard.
  4. HP Pavilion dv6000 Wireless Card Replacement: adım 4, 1 resimden 1.
    • Wireless card remains.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ben Hirsch
3.826 İtibar
10 adet Kılavuz yazıldı
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010 üyesi
CPSU-REGAN-F10S21G33
4 Üyeler
12 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 26,517
