Giriş
Is your key stuck sometimes, are you missing any key caps or is the keyboard unresponsive in general? Replacing your keyboard may solve these problems and render your laptop usable again.
Neye ihtiyacın var
Remove fifteen 7.0mm PH0 screws.
Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Je constate que régulièrement, il n’est pas mentionné de se décharger de son électricité statique. En dehors de tout équimement spécifique, il suffit, par exemple de toucher le bouton de purge d’un radiateur de chauffage central ou la fiche “terre” d’une prise 2 + T
