Giriş
This guide would be used if your screen gets damaged or no longer functions. All screws are a PH00 size. It would be advisable to keep track of which screws go where, as there are a lot of screws that will be removed over the course of this guide. Be sure to wear the anti-static guard strap, as that will protect the circuitry from permanent damage from static electricity.
Neye ihtiyacın var
Flip over the device so that the bottom is facing you.
Locate the battery on the bottom of your laptop.
2 farklı kişi bu kılavuzu tamamladı.
