Ana içeriğe geç
HP Pavilion dv6700 Heat Sink Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6700 Heat Sink Replacement, Battery: adım 1, 1 resimden 1.
    • Flip over the device so that the bottom is facing you.
    • Locate the battery on the bottom of your laptop.
  2. HP Pavilion dv6700 Heat Sink Replacement: adım 2, 2 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 2, 2 resimden 2.
    • Slide the tab all the way over to the left until battery pops out. Lift out and remove battery.
  3. HP Pavilion dv6700 Heat Sink Replacement, Display/Monitor: adım 3, 2 resimden 1. HP Pavilion dv6700 Heat Sink Replacement, Display/Monitor: adım 3, 2 resimden 2.
    • Remove the RAM port cover by unscrewing the two screws.
    • These screws can not be fully removed because they’re captive. Loosen them until they turn freely.
  4. HP Pavilion dv6700 Heat Sink Replacement: adım 4, 2 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two screws securing Hard Disk Drive (HDD) cover.
    • Screws will not fully remove. Loosen them until they turn freely.
  5. HP Pavilion dv6700 Heat Sink Replacement: adım 5, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 5, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the 25 screws securing the bottom of the computer.
  6. HP Pavilion dv6700 Heat Sink Replacement: adım 6, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 6, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 6, 3 resimden 3.
    • Detach WiFi antenna wires.
    • Be sure that the wires are labeled so you remember which ones go where.
  7. HP Pavilion dv6700 Heat Sink Replacement: adım 7, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 7, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 7, 3 resimden 3.
    • Using the Phillips #0 screwdriver remove the 2 screws.
    • Use a needle-nose pliers to do the initial loosening, then switch to using a hex screwdriver (size 5) head to do the rest of the loosening.
  8. HP Pavilion dv6700 Heat Sink Replacement: adım 8, 2 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 8, 2 resimden 2.
    • Flip over HP Pavilion dv6700 so that the top is facing you.
    • Open up HP Pavilion dv6700.
  9. HP Pavilion dv6700 Heat Sink Replacement: adım 9, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 9, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 9, 3 resimden 3.
    • Use an iFixit opening tool to pry open the plastic bar above the keyboard.
    • Be careful not to yank so hard that you rip out the ribbon cables underneath. There is enough room to pull safely, but use control to prevent damage.
  10. HP Pavilion dv6700 Heat Sink Replacement: adım 10, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 10, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 10, 3 resimden 3.
    • Pull out and up on keyboard to remove it.
    • Do not yank it all of the way out, as there is a ribbon cable underneath.
    • Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
    • Grip the ribbon cable near the connection point and gently but firmly pull it out.
  11. HP Pavilion dv6700 Heat Sink Replacement: adım 11, 2 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 11, 2 resimden 2.
    • Flip over the plastic bar.
    • Detach the display connector.
    • Do not pull on the wires. Pull on the black plastic part or wedge an iFixit opening tool or fingernail between the port and the connector.
  12. HP Pavilion dv6700 Heat Sink Replacement: adım 12, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 12, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 12, 3 resimden 3.
    • Detach the ribbon cables.
    • Pull from the area closest to the connection port gently but firmly.
  13. HP Pavilion dv6700 Heat Sink Replacement: adım 13, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 13, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 13, 3 resimden 3.
    • Pull up on tape holding down wires.
  14. HP Pavilion dv6700 Heat Sink Replacement: adım 14, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 14, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 14, 3 resimden 3.
    • Pull up on the WiFi wires and out from under the metal tabs.
    • Do not yank them out. Let them hang loose once they are out from under the tabs.
  15. HP Pavilion dv6700 Heat Sink Replacement: adım 15, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 15, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 15, 3 resimden 3.
    • Disconnect the connector from the port.
    • Remove the wire from under the metal tabs.
    • Let wire hang loose after removing under the tabs.
  16. HP Pavilion dv6700 Heat Sink Replacement: adım 16, 2 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 16, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the black screw located in the top right corner near the display.
  17. HP Pavilion dv6700 Heat Sink Replacement: adım 17, 2 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 17, 2 resimden 2.
    • Pull upward on the screen connector tab.
    • It will be firmly secured, so don't be afraid to use a little extra force to pull it off.
  18. HP Pavilion dv6700 Heat Sink Replacement: adım 18, 2 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 18, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the black screw securing the screen.
    • Keep your hand on the screen to secure it, as once you remove this screw, it will come loose.
    • Lift the screen off and set it aside.
  19. HP Pavilion dv6700 Heat Sink Replacement, Motherboard: adım 19, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement, Motherboard: adım 19, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement, Motherboard: adım 19, 3 resimden 3.
    • Unscrew the black screw in the top right corner using the Phillips #00 screwdriver.
    • Pull up on the top piece and remove it.
  20. HP Pavilion dv6700 Heat Sink Replacement: adım 20, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 20, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 20, 3 resimden 3.
    • Remove the screw in top left corner using the Phillips #00 screwdriver
    • Remove the five screws that are located on the motherboard cover.
    • Pull up on the cover to remove it.
    • You can use a plastic opener if it is hard to get your fingers under the cover's edges.
    • Do not pull hard on the cover, as there are two ribbon cables under the cover connected to the motherboard.
  21. HP Pavilion dv6700 Heat Sink Replacement: adım 21, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 21, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 21, 3 resimden 3.
    • Pull gently but firmly on the ribbon cables at the connection points to remove them
  22. HP Pavilion dv6700 Heat Sink Replacement: adım 22, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 22, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 22, 3 resimden 3.
    • Remove the four screws from the ExpressCard component using the Phillips #00 screwdriver.
  23. HP Pavilion dv6700 Heat Sink Replacement: adım 23, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 23, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 23, 3 resimden 3.
    • Remove ExpressCard component by sliding it out.
    • Remove Optical Drive by sliding it out.
  24. HP Pavilion dv6700 Heat Sink Replacement: adım 24, 2 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 24, 2 resimden 2.
    • Detach connector from the motherboard.
    • This piece is likely to be very hard to disconnect, so do not be afraid to use more force than normal.
  25. HP Pavilion dv6700 Heat Sink Replacement: adım 25, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the one screw near where the ExpressCard component was.
  26. HP Pavilion dv6700 Heat Sink Replacement: adım 26, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 26, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 26, 3 resimden 3.
    • Lift up motherboard.
    • Detach the motherboard connector at the front under the motherboard.
  27. HP Pavilion dv6700 Heat Sink Replacement: adım 27, 3 resimden 1. HP Pavilion dv6700 Heat Sink Replacement: adım 27, 3 resimden 2. HP Pavilion dv6700 Heat Sink Replacement: adım 27, 3 resimden 3.
    • Lift up and out the motherboard.
    • Detach the connector under the motherboard.
    • Remove the motherboard.
  28. HP Pavilion dv6700 Heat Sink Replacement, Heat Sink: adım 28, 1 resimden 1.
    • Using a Phillips #0 screwdriver unscrew the 5 screws located on the mother board.
    • The screws will not come out of the heat sink - just out of the motherboard.
  29. HP Pavilion dv6700 Heat Sink Replacement: adım 29, 1 resimden 1.
    • Pull out connector from motherboard port.
  30. HP Pavilion dv6700 Heat Sink Replacement: adım 30, 1 resimden 1.
    • Remove heat sink.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 28
Her zaman: 1,509
