Giriş
This is for if you need to get into the guts of the HP Pavilion dv6700. Be sure to have the anti-static strap on, as you will be coming into contact with circuitry and could permanently damage the pieces with static electricity.
Neye ihtiyacın var
Flip over the device so that the bottom is facing you.
Locate the battery on the bottom of your laptop.
Unscrew the black screw in the top right corner using the Phillips #00 screwdriver.
Pull up on the top piece and remove it.
8 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Thank you for all your help . Very decent of you.
Spot on guide and detail.
Ian, Poynton< Cheshire
UK.
