Ana içeriğe geç
HP Pavilion dv6t-1200 Disk Tray Motor Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6t-1200 Disk Tray Motor Replacement, Disk Tray Motor: adım 1, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Motor Replacement, Disk Tray Motor: adım 1, 2 resimden 2.
    • Locate the small hole on the right side of the disk tray next to the release button.
  2. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: adım 2, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: adım 2, 2 resimden 2.
    • Extend the paper clip into a straight line and insert it into the disk tray hole located next to the release button.
    • Do not poke the optical light button to the middle left of the release button. The disk tray hole is to the bottom right of the tray release button.
    • When the disk tray is removed, clean your workspace and the tray with canned air.
  3. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: adım 3, 1 resimden 1.
    • Be cautious of the open disk tray.
    • Flip the laptop upside-down.
    • Remove the four screws on the bottom of the disk tray using a Phillips #0 screwdriver.
  4. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: adım 4, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: adım 4, 2 resimden 2.
    • Remove the top metal plate of the disk tray and locate the motor.
  5. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: adım 5, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: adım 5, 2 resimden 2.
    • Remove and replace the motor piece.
  6. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: adım 6, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: adım 6, 2 resimden 2.
    • After replacing the motor and screwing the tray back together, apply WD40 to lubricate the tray.
    • The disk tray should now be working smoothly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Pelayo
210 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 351
