Ana içeriğe geç
HP Pavilion dv6t-1200 Disk Tray Replacement
Neye ihtiyacın var
  1. HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: adım 1, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: adım 1, 2 resimden 2.
    • Locate the small hole on the right side of the disk tray next to the button.
  2. HP Pavilion dv6t-1200 Disk Tray Replacement: adım 2, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Replacement: adım 2, 2 resimden 2.
    • Extend the paper clip into a straight line and insert it into the disk tray hole located next to the release button.
    • When the disk tray is removed, make sure to clean the general area with canned air.
  3. HP Pavilion dv6t-1200 Disk Tray Replacement: adım 3, 1 resimden 1.
    • Flip the laptop to the other side and remove the four screws on the bottom of the disk tray using a Phillips #0 screwdriver.
  4. HP Pavilion dv6t-1200 Disk Tray Replacement: adım 4, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Replacement: adım 4, 2 resimden 2.
    • Remove the metal plate and locate the bottom right tool for the disk tray.
  5. HP Pavilion dv6t-1200 Disk Tray Replacement: adım 5, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Replacement: adım 5, 2 resimden 2.
    • Replace the motor piece that is being held and reclose the device.
  6. HP Pavilion dv6t-1200 Disk Tray Replacement: adım 6, 2 resimden 1. HP Pavilion dv6t-1200 Disk Tray Replacement: adım 6, 2 resimden 2.
    • After replacing the motor and the placing the metal tray apply a good amount of WD40.
    • Once all completed the disk tray should be working smoothly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Pelayo
210 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 265
