Ana içeriğe geç
HP Pavilion dv7-1285dx Back Plate Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: adım 2, 1 resimden 1.
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Back Plate Replacement: adım 3, 2 resimden 1. HP Pavilion dv7-1285dx Back Plate Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to lift up the back plate and set it aside.
Sonuç
Chris Apple
239 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G34
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,538
