Ana içeriğe geç
HP Pavilion dv7-1285dx RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7-1285dx RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
    FixBot'a Sor
    Yorum Ekle
  2. HP Pavilion dv7-1285dx RAM Replacement, Back Plate: adım 2, 1 resimden 1.
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
    FixBot'a Sor
    Yorum Ekle
  3. HP Pavilion dv7-1285dx RAM Replacement: adım 3, 2 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to lift up the back plate and set it aside.
    FixBot'a Sor
    Yorum Ekle
  4. HP Pavilion dv7-1285dx RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Rotate the device 90 degrees to the left.
    FixBot'a Sor
    Yorum Ekle
  5. HP Pavilion dv7-1285dx RAM Replacement: adım 5, 3 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 5, 3 resimden 2. HP Pavilion dv7-1285dx RAM Replacement: adım 5, 3 resimden 3.
    • Locate the grey clips on the side of the RAM and pull the grey clips away from the RAM using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  6. HP Pavilion dv7-1285dx RAM Replacement: adım 6, 3 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 6, 3 resimden 2. HP Pavilion dv7-1285dx RAM Replacement: adım 6, 3 resimden 3.
    • Unplug the RAM.
    • Repeat step 6 to remove the second piece of RAM.
    FixBot'a Sor
    Yorum Ekle
  7. HP Pavilion dv7-1285dx RAM Replacement: adım 7, 2 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 7, 2 resimden 2.
    • These steps are important in the replacement of the RAM, they will assist in ensuring the device is not damaged.
    • Align the notch in the new RAM with the peg on the plug
    • Ensure the RAM is fully inserted into the plug at a 45 degree angle such that the notch of the RAM lines up with the peg on the plug
    FixBot'a Sor
    Yorum Ekle
  8. HP Pavilion dv7-1285dx RAM Replacement: adım 8, 2 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 8, 2 resimden 2.
    • Push down gently on the RAM until the grey clips click.
    • Repeat steps 7 and 8 to replace the second piece of RAM.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jesse Quisido
513 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G34
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 1,401
